moldings
i am attempting to create a coffered ceiling and i'm stuck on how to go about adding the moldings. currently i use morphs to get the desired shape, please advise on best method (if it isn't morph) and how to get the moldings.. grateful for any help
8 REPLIES 8
Dontknow
Made a video for you of an example of morph pulling.
Hope this helps you.
Architectural construction designer, draftsman, modeller
ArchiCAD 25.
David Maudlin
coxy761:
Another approach is to make a Complex Profile of the molding, create one section then copy it around.
David
David Maudlin / Architect
www.davidmaudlin.com
Digital Architecture
AC29 USA Perpetual • Mac mini M4 Pro OSX15 | 64 gb ram • MacBook Pro M3 Pro | 36 gb ram OSX14
mikas
I would use custom profiles. It is really easy to change the profile or adjust it later on.
(I lost just a few seconds to David..)
AC27, Rhino7/8+Grasshopper, TwinMotionMac Pro 6,1 E5-1650v2-3,5GHz/128GB/eGPU:6800XT/11.6.5 • HP Z4/Xeon W-2195/256GB/RTX4080FE 16GB/W11ProWS
This was very nice of you to do. It's worth pointing out that the Morph's tube command can be used in conjunction with the Magic Wand tool, and the profile could have been extruded around the entire perimeter in about 1 second. http://www.shoegnome.com/2013/05/14/archicad-modeling-tips-bonus-video/
Richard
AC26 (since AC6.0), Win10
Thank you everyone for your replies and assistance, it's good to get many options... many thanks
Dontknow
Thank you.
I've been experimenting with this as well but it doesn't always work. strangely.
As you can see in this video.
ArchiCAD 25.
mikas
This is for your further study coxy.
Create a new profile and name it; draw profile section with fill tool, assign it to be used with walls (see red rectangle in screenhot), save it. And then go to plan view, open wall tool, order a wall to be "profiled wall", assign your just created profile to it, and then draw your geometry in plan view. You might want to do a sketch with line tool first maybe, and the use the Magic wand as suggested in the other method too. You might do copy, mirror etc. what ever works to get the desired geometry. Hope this helps.
Steve Jepson
and when you are done modeling it as complex profile you may want to convert it to a morph in order to smooth the curves.
