morph tool
Hello.
I have a problem. I selected a number of objects (beams) and converted all at once into morphs. Now when I try to select, I cannot do it individually, but only as a bunch, as I have transformed them.
Do you happen to know hoe I might split the bunch?
Thank you very much.
3 Replies 3
See if Suspend Group helps,
Edit > Grouping > Suspend group
If you have merged(union) "bunch" of morphs into 1 element, then you need to split them individually one by one.
Cheers
AFAIK the split command is the only way (aside from remaking the parts from scratch). I use the split command so often that I have assigned it to the backslash key (no modifiers) which would also speed your process.
Keep in mind that if you use it in 3D the reference line elevation of the split command will be at the current user origin. You may want to reposition this to make it easier.
Hello again.
Thank you for both the answers. I tried the first suggestion and it worked out.
Thank you again.
