moving guide lines
Dave Brach
one thing I love about sketchup is offsetting guidelines with two clicks using the tape measure, and I was looking for a way to do this in archicad.
the archicad reference guide says "to move an existing guide line to a more useful location, move the cursor to the guide line. Click on the orange dot, then move the guide line". When I click on the orange dot, the dot disappears and the guide line stays put. what am I missing?
Dave Brach/architect
AC26 MBP OS Ventura
AMD Radeon Pro 5300M 4 GB
Intel UHD Graphics 630 1536 MB
7 REPLIES 7
sinceV6
It should say:
... Click & drag the orange dot, then release at the desired position....
Best regards.
Dave Brach
of course, thanks!
AC26 MBP OS Ventura
Eduardo Rolon
and you can draw a guide between 2 points just like in SU. Start a command (line, wall, etc) hit the Guide Line Shortcut key, draw the Guide line and in the screen shot you can select the midpoint of the guide.
Eduardo Rolón AIA NCARB
AC27 US/INT -> AC08
another Moderator
Eduardo Rolon
midpoint…
AC27 US/INT -> AC08
another Moderator
And when dragging a guide line if you press CTRL you will get a copy.
Stress Co_
Or press "option" if on a mac.
Marc Corney, Architect
Red Canoe Architecture, P. A.
sinceV6
Or create a new one on-the-fly by hovering a parallel edge -from another element- to your desired guideline and drag the orange dot (meaning that there doesn't need to be a previous guideline to be dragged)
