multiple drag/mirrpr/copy command
Llian
I don't seem to be able to get this shortcut command...what key is the first symbol on the extreme left next to the command symbol? I tried control, alt and shift and they just don't seem to get the multiple command work...please help. thanks
Lilian Seow LEED AP | cSBA | CAPM | PMP
AC28 USA | Windows 11 Enterprise i5 3.10GHz | Archicad-user since 1994!
Start the drag command (CMD-D). If you then hit the Option key a small plus appears next to your cursor to drag a copy. If you hit Option AND Command keys you will get 2 plus symbols next to your cursor which indicates multiple copies.
Also works with rotate and mirror commands
Llian
Thanks Stuart....yes it works.
