new user door and window problems
Options
- Mark as New
- Bookmark
- Subscribe
- Mute
- Subscribe to RSS Feed
- Permalink
‎2013-11-21
11:18 PM
‎2023-05-24
09:07 AM
Rubia Torres
‎2013-11-21
11:18 PM
For windows I typically have 3-studs between multiple windows and am not sure how to do this. If I do individual windows the trim does not merge. If I try it as a ganged window, it does not show where mulled correctly. Is there a way to do this?
Any tips or thoughts would be greatly appreciated!
Thanks
Options
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
‎2013-11-22 12:06 AM
‎2013-11-22
12:06 AM
Dogwood wrote:You can set Special Snap Points to work Between Intersection Points, which would be a good start. See image below.
I am using 17, and struggling with the way archicad inserts doors and windows. Is there not a way to have doors insert a specific distance off of adjacent walls? I typically put the door jamb 4-1/2" off of an adjacent wall. If I use the 'distance' markers, they do not coincide with the adjacent wall and thus are useless. ...
Thanks
You can also place things relative to a known point as described in THIS THREAD (link) and many others on the forum. Be aware there are a few tricks for you Imperial users.
Options
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
‎2013-11-22 08:01 PM
‎2013-11-22
08:01 PM
Ahaa! Thanks Stuart, that helps.
