not dimensioning walls
how do you stop the dimension tool from indicating the thickness of a wall when i only want to start the dimensions from the edge of a wall?
wb
If you click on the edge of a wall then you will automatically get two markers at the centre of the length of the wall that will determine the wall thickness (as you have discovered).
Just click on the marker that you don't want and it will delete leaving just the one you require.
Or don't click on the edge of the wall, click on a node at the end of the wall and you will get just the one point.
Thanks Barry, that's been driving me nuts for ever.
h
