object behavior
Is there a way, such as a script edit, to have an object behave and enable mercedes cursers on the sides of the object similar to lines, slabs, fills, etc? I started to use the "column grid marker NCS" object symbol but when i want to reference a distance from the column line I can only do it by zooming out to the hotspots of the object. Is this by any chance a new feature in AC9.0?
10 REPLIES 10
Ben Odonnell
Eric,
Check under the help menu, there is a whole section dedicated to GDL.
You will find the answer to your question in there.
Cheers.
Ben
Ben O'Donnell
Architect and CTO at BIMobject®
Get your BIM objects from bimobject.com
This is a new capability in 9.0
cheers,
Woody
__archiben
Eric wrote:
Is there a way, such as a script edit, to have an object behave and enable mercedes cursers on the sides of the object similar to lines, slabs, fills, etc??
as ben said - check the GDL manual. you are looking for the HOTLINE2 command in particular (i think!). it enables any such line defined in the object to behave as a snappable line (just as a normally drawn line) in the working window.
there is also HOTARC2, as well as the traditional HOTSPOT2 . . . when do we get a HOTFILL2 graphisoft?
HTH
~/archiben
b e n f r o s t
Link
Probably just after HOTTAMALES2, HOTMEATPIE2, & HOTCHICK2.
Link.
Ben Odonnell
Or mabe even, HOTLINK2
Ben O'Donnell
I dont see the HOTLINE2 in the help menu or the GDL manual. Is this script for 9.0 and not available with 8.2?
Thanks for all you help
As I said earlier... this is a new feature in 9
woodster
Ben Odonnell
Eric,
Do a search in your help menu, there is quiet a bit about of info about it.
Cheers.
Ben
Ben O'Donnell
Thanks Woody I did see your ealier responce. I just wasnt sure if it was scriptable in 8.1 and aready in the new parts for 9.0. Now I just need to get the powers that be to get some new machines and 9.0.
Thanks again
