object insert
when i am trying to put new objects like bed chair etc., along with that is rectangular box like which is filled in green colour with dots comes and it overlap my walls and other obects. I do not know why? Please help.
Thank you
3 Replies 3
that sounds like the 'minimal space' option that can be turned off as a global setting in your Model View Options.
go to Document>Set Model View>Model View Options
here you can define and save a Model View Option Combinations for particular views, for example you could save a MOV for floor plans, for Site plans, etc.
Go to Options for GDL Objects and untick the "Show Minimal Space"
then apply the chosen combination to your view maps in the navigator.
thank you Mark it worked, actual i trying to learn archicad, i do not much know about the software.
Thanks for your help.
Thank you
no problem. check out Youtube as well - there are a lot of training videos on there and a dedicated Archicad channel.
