objects, walls, complex profiles etc > follow path
Is there any way to evenly distribute elements so as to follow a path (spline polyline etc)?
The Edit\Distribute\Special Distribute command should do the trick.
See the Help file for details on its use.
Erich
Of course the Distribute command was new in AC12.
Erich
AC 19 6006 & AC 20
Mac OS 10.11.5
15" Retina MacBook Pro 2.6
27" iMac Retina 5K
Thank you. It works.
