2009-01-26 06:43 PM
2009-01-29 06:23 PM
Erich wrote:Actually, this is something entirely different. The Merge Walls does not join separate pieces of wall that are broken along their length. Rather, it takes several walls that are placed next to each other to represent a single wall and creates a profile that allows the assemblage to be drawn as one wall.
This is possible to do with the tools we currently have. Select both walls, go the to Model Menu>Select Complex Profiles>Select Merge Walls. While it is perhaps not the most obvious place to look, it does work and your previously split walls will become one.
2009-01-29 06:28 PM
2009-01-29 06:59 PM
2009-01-29 07:00 PM
Rakela wrote:Hi Raul,
can you convert to a regular wall ? after the joining ?
2009-01-29 07:10 PM
2009-01-29 07:18 PM
2009-01-30 02:14 AM
2009-01-30 04:04 PM
2009-01-30 06:07 PM
Chazz wrote:If I had the power. I copied the tip into the Tips forum so that GS will see it in case they are still giving tip awards.
Karl, can we send Erich the tee-shirt and coffee mug?
2009-01-30 07:53 PM
