Streamline your workflows and master BIM coordination! Program starts April 28.!
own working environment and how to get it to another PC
Hallo, I am working with AC10 (1010) EDU and I would like to know, what should I do if I want to have own working environment in another PC. I work at home and when I come to school all pallets are in default.
Please help what should I do if want to have my rorking environment on PC were I have never been. Thank you very much
Suppose you use cz version.
So when you set your own environment go to "volby-pracovni prostredi-pracovni prostredi" select "schemata paletek", save it under any name and export it somewhere to your hard drive. Do the same with "rozvrzeni nastroju" and "schemata klavesovych skratek" if you want. Copy these settings to USB key, CD, floppy or so and take it to another PC. Then import them just the way you have exported them.
PS
I guess it is easier for you to go to archiforum.cz for help.
Roman
________________________________________________
AC10CZ
Ahoj, děkuju moc, to jsem přesně chtěl vědět. O české verzi vím, ale zkouším to střídat, ahoj
