paint and tiles how
1. Plaster on brick wall surface and paint
2. Plaster on brick wall end surface and paint
3. tiles on column with morter
4. plaster on brick wall adjacent to column-tiles
For better understanding see attached image
is it possible? this is just one blow up. I have to do for big project with frequent change and quantity survey.
Plz guide me best way.
3 Replies 3
The walls can be regular composite walls with skins for each material.
The ends you will have to do with a 'Wall End' tool if you want a thickness - otherwise just change the wall end surface.
The column will need t be a complex profile column unless you want to model the plaster/tile skin separately.
Thank lot. I can understand wall and wall end tools.
But did not understand "plaster/tile skin separately, " How can I do plaster/tiles skin separately?
is there any way to just make skin like surface paint.
For example I have a wall with door and window. And I want to make put tiles on one surface?
thnx again
I was referring to the column in the corner.
Add a separate skin (wall) for the plaster/tiles.
Or create a complex profile column as suggested in your other post here ....
https://archicad-talk.graphisoft.com/viewtopic.php?f=20&t=71652
For a wall just create a composite wall with the skins you require.
If you want the tile/plaster skin to be adjustable in height or thickness you will have to model separately or again you can use a complex profile wall (with or without modifiers) - as mentioned in your post here ....
https://archicad-talk.graphisoft.com/viewtopic.php?f=20&t=71665
