2021-12-01 10:28 AM
good morning to all!
could i insert a sub-scale drawing in pdf format as a trace and draw my floor plan? can i catch points from pdf?
thanks!
2021-12-01 10:40 AM
Yes.
The quick way to do it is to choose the view to which you want to insert the drawing > set the scale to the same as pdf drawing > drag the pdf file into the view > right-click the drawing object > explode into current view.
This results in the PDF vectors being converted to AC lines to which you can snap.
2021-12-02 06:26 AM - edited 2021-12-02 06:29 AM
To be precise, no, the pdf has nothing in it you can snap to. But yes, like thesleepofreason has said it. However, - if you explode the .pdf and it is not the scale you wanted, you can select all of it and resize it the same way you can resize a 2d image to a known scale. Sometimes the .pdf is generated as print-to-fit and might be some very odd scale.
27B USA 2202 Win64 FULL- TESTING ONLY2021-12-02 10:03 AM - last edited on 2021-12-02 10:22 AM by Barry Kelly
If you drop the PDF into a worksheet at the right scale, you can trace reference that worksheet and draw on top.
If the PDF is a vector type, you can explode it and use the snap points. However if it’s a raster PDF you can't explode it
