2006-12-30
08:31 AM
- last edited on
2023-05-23
05:11 PM
by
Rubia Torres
2007-01-02 09:34 AM
Dwight wrote:Weird...too bad...and yuch
On the other hand, as I've said before, with my four year old machine, the problem occurs and then does not. I cannot assign any operation, video card problem or other hardware explanation to it.
Problem files can be sent to other users who can see the same ECBI in the file.
Boogle.
2007-01-02 09:37 AM
Dwight wrote:Heh, i found out your acronym the first
But you didn't search for the Evil Chopping Block of Invisibility, did you? So obvious.
I recoommend that you merge your data into a new project file. The persistent, camera-related ECBI seems to scurry once the data is transferred.
2007-01-02 09:40 AM
Matthew wrote:Ye, i have read that u mentioned this in another topic. Thx for advice, im gonna try it today on much stronger machine. If it still remain, i would have to get used to it
Do you have access to another computer that you can test the file on? At my client's office the problem was confined (as I recall) to one project on only one machine. If it is a problem with the computer (even if a clean merge fixes the problem file) it will probably recur. An upgrade or replacement may be in order.
