Guillermo1
pipe home story
Hi, in floor plan view when i model a pipe with -0,30 meters below the slab, automatically change the home story to the level below.
is there a way to keep the actual level of the pipe?
2 Replies 2
Xandros
I'm not sure if MEP elements are influenced by this setting but I'll give it a shot:
Have you checked if this setting box Set Home Story by Elevation is off?
https://help.graphisoft.com/AC/26/INT/_AC26_Help/040_ElementsVB/040_ElementsVB-4.htm#XREF_18618_Set_...
ArchiCAD 27 GER / Win10
Intel i9-9900K / 64GB RAM / nVidia GeForce RTX 2080 Ti
Guillermo1
thak you Xandros but is not working, or im doing something wrong
