pla file is better than pln file???
what do you usually save your archicad file as? pla? pln? which is better? why?
2 Replies 2
One is not so much better than the other - they each have entirely different purposes.
A PLA archive is to include all related library parts and textures (etc) in a single file for moving to another machine or for archiving at the end of a project. It will be very much larger than a PLN, which should be the workaday file format - unless you have reasons to use TeamWork.
thanks!! karl
