plot maker is awful
- Mark as New
- Bookmark
- Subscribe
- Mute
- Subscribe to RSS Feed
- Permalink
ā2005-04-25 10:48 AM
What do other people use.
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
ā2005-04-25 11:42 AM
plot maker is the most awful program.... do i have to use it? is there something else... it's so frastrating and slow i've spent half my time setup drawings in plot maker, some times more time then to do the archicad drawing.. the commands do work the same etc... i think it would be quicker and easyier to use autcad in replacement of plot maker....
Question number ...
1) what version are U referring to - 5.0?
2) have U done any training (= are you using PM correctly)?
3) are you sure you want to convert to ArchiCAD?
because ...
What are U expecting from a CAD program?
Dumb 2D drawings where you have to copy and paste to get any elevation and section information at all but with a "fast" print layout
or ...
an object intelligent 3D program that automatically gives U the 3D info (and calculations if needed) in any view but might be a bit "trickier" to do paper layouts in if no user training has been adapted?
In the scenarios above - where would U save the most time (again, with a bit of tutoring maybe)?
Hmmm, tough one ...
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
ā2005-04-25 12:19 PM
Personally i find plotmaker good and i am using it on a below minimum spec machine
OSX 10.15.6 [Catalina] : Archicad 22 : 15" MacBook Pro 2019 [/size]
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
ā2005-04-25 03:39 PM
I did an experiment I drew the initial 3d drawings etc in archicad a used Autocad in replacement for plot maker it was 1/2 to 3/4 faster for a better result... it was eaiser more pricise... and i wasn't panicking to get my next job out... I xreffed the drawing into autocad in five seconds.. size raster images to size straight away... and easily noted my sections etc.
dale
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
ā2005-04-25 03:40 PM
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
ā2005-04-25 04:13 PM
(A) laying out Viewports
(B) Filling out Reference Markers
(C) Numbering Sheets in order and/or by subset
(D) Plotting them out.
It's lovely that you can XREF a single drawing into Autocad faster than you could with Plotmaker, but how long does it take you to plot a 50-sheet set? How long do you spend filling out reference bubbles? How long would it take you to insert a sheet in the set, renumber the affected sheets, and correct the reference markers to refer the the new location?
Sounds to me like you need to learn a little more before you display your ignorance for the masses. Anyone can blame the software for their lack of ability instead of learning how to use it. This kind of atttitude towards learning and improvement could explain why you are looking for work.
While I agree Plotmaker needs a lot of improvement, it is excellent at what it does, even if that is ALL it does.
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
ā2005-04-25 05:09 PM
dbroughton wrote:You must be using a different program than I am, because I find plotmaker to be quite a good layout program. It has it's quirks, but have someone show you how it is intended to be used and you will never turn back.
plot maker 9 is awful
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
ā2005-04-25 10:18 PM
the big advantage to Plotmaker, regardless of quirks flaws, etc, is the second project - once you have synchronized your ArchiCAD template for a given building type with the Plotmaker template.
Then the links all work and update when you change the project.
Ba doo ba ding.
Slogan if they ever need to market Plotmaker, which they won't: "Plotmaker: It's a PLOT!"
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
ā2005-04-26 08:15 PM
dbroughton wrote:You did list all your gripes that objectively do exist in PlotMaker.
You made some good points but PM is just not fast enough for me...
But, try to do the following in AutoCAD:
- automatically number all the sheets
- do the whole project in one file
- import DWF
- print to PDF without buying additional software
- open the same AutoCAD drawing on a different machine and find your placed images
- overlay as many drawings as you like, changing pens and colors and whatnot
Now again a quote from Murphy's Law:
- Everything works better if you switch it on
- Computers never do what we want, only what we tell them to do
As Miyamoto Musashi once said, you should study this.
ArchiCAD since 4.55 ... 1995
HP Omen
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
ā2005-04-27 12:35 AM
Dwight wrote:Ahh, the Plot thickens........
Red Canoe Architecture, P. A.
