polygon degenerated (SLA-029)
damnnnnn
i dont have time for this stu** error
copy all slabs into new file.. still this error.. i deleted one by one and now i dont have any slab.. but this error still here
plzzz helpp..
7 Replies 7
baklazh wrote:
damnnnnn
plzzz helpp..
I'm guessing you won't be able to select the slab with the error because it wouldn't be displaying.
Now they are all gone, activate the slab tool and then press CTRL-A (select all slabs) and see what turns up.
Otherwise use Find & Select to find the slab with an ID of "SLA_029".
Once selected you might be able to figure out what is wrong with it - or delete it.
THHHHAAAAAAAAAAANKKKKKKKKKKKYYYYYYOUUUUUUUUUU
and.. what shoud i buy to increase speed of converting to 3d ?
i have
1gb ram
3.2Ghz
GeForce 6600 GT
but too slow for 5 storie building
i have
1gb ram
3.2Ghz
GeForce 6600 GT
Double the RAM, gruntier graphics card and turn off the layers you dont need to be displayed.
THNX BARRY.... MY PROBLEM WAS SOLVED.......
COMMAND+F, SELECT USING UR ERROR ID (SLA - 008 IN MY CASE)
EITHER DELETE IT AND CREATE NEW OR CORRECT IT....
I'm glad it is still helping even after 3 years!
And well done for searching through the old posts instead of just making a new one.
That is the way forums should be used.
This worked for me too, just now! Thanks!
