polygon is degenerated
Why it happens? It writes polygon is degenerated, slab xyz, what is problem? Please help
4 REPLIES 4
David Maudlin
petrabgr:
There must be a geometrically impossible condition with the Slab, like the perimeter crossing itself. You will need to find which Slab has the error, then fix its problematic area.
David Maudlin / Architect
www.davidmaudlin.com
Digital Architecture
I am working in Archicad 17, on computer at college and I know in which slab is problem but I don´t know what to fix in it
David Maudlin
petrabgr:
If you cannot see what the problem is with the Slab, then it might be simpler to recreate it: option-click the existing Slab to pick up its attributes, then trace its perimeter to create a new slab. Sometimes there can be a very small error at a corner that causes a geometrically impossible situation, but there are many possible causes for the error.
thanks...........
