Starting August 6, 2024, TLS 1.2 will be the minimum required protocol version for Graphisoft products and services that require an online connection. License Manager Tool update is required on Windows. Learn more…
2015-04-0411:16 PM - last edited on 2023-05-2407:01 PM by Rubia Torres
Hello
A couple of hours ago, I tried to perform SEO with a shell to make some holes in it, the operation was apparently performed (the counter of SEO reseted and the nodes appeared on the shell), but when I deleted the operating elements of the shell, the SEO had made no changes on it, only turning the shell into a morph permanently showed the subtraction, this issue is present also with any other type of element, anyone knows how to fix this?
The items used for thee solid elements operations need to be retained for the SEO to be maintained, if you do not want to see the elements just place them on a lay that is hidden.
