Solid Element Operations Problem
Hello
A couple of hours ago, I tried to perform SEO with a shell to make some holes in it, the operation was apparently performed (the counter of SEO reseted and the nodes appeared on the shell), but when I deleted the operating elements of the shell, the SEO had made no changes on it, only turning the shell into a morph permanently showed the subtraction, this issue is present also with any other type of element, anyone knows how to fix this?
Thanks in advance
1 Reply 1
Chema,
The items used for thee solid elements operations need to be retained for the SEO to be maintained, if you do not want to see the elements just place them on a lay that is hidden.
Scott
