Hello
A couple of hours ago, I tried to perform SEO with a shell to make some holes in it, the operation was apparently performed (the counter of SEO reseted and the nodes appeared on the shell), but when I deleted the operating elements of the shell, the SEO had made no changes on it, only turning the shell into a morph permanently showed the subtraction, this issue is present also with any other type of element, anyone knows how to fix this?
Thanks in advance
