prevent 3d window from popping up when you change 3d engine
Haneef Tayob
Hello
I'm using the AC9, windows version.
Is there a way to prevent archicad automatically jumping into the 3d window once you change any setting in [3d Engine and Mode] under the pulldown menu?
I often find myself changing 3d modes (especially to from shading to hidden line and vice versa. It's a time problem when the 3d window pops up each time and the whole model tries to generate (unless you remember to place a small marquee or select an item before you attempt to change the mode).
Any suggestions?
Haneef Tayob
Aziz Tayob Architects
AC23 INT rel 3003, OS X 10.14.6 iMac 3.3ghz i5 dual monitor, 24GB RAM
Check your work enviornment; there is a setting under Imaging and calcuation to allow 3D settings to bring the 3D window to front.
Haneef Tayob
39minutes for a reply ':D'
Thanks a lot it works. Been using AC for so long and don't know how I missed it.
Haneef Tayob
