print a scaled 3d view
hi
i want to know how to print a scaled axonometric view? cause it only allow me to print based on the zoom i decide so i cant get the scale right...
i hope you understand what i want... thanks
Djordje
Ace
Luiscardoso wrote:
hi
First make sure that all the axes are not scaled - so that is really an isometric, not an axonometric view.
Then, when you set it up in the 3D window, changing the 3D engine to Internal, set it as a view. You can set the scale there. Place on the layout. Done.
Djordje
ArchiCAD since 4.55 ... 1995
HP Omen
Djordje wrote:
Luiscardoso wrote:
hi
Hi Djordje!
I'm not sure about the settings. Please take a look at the settings in the attatched image. Is this not scaled, as you put it?
Is it right to set all the parameters to 1000? I've also tried with 500, but then it came out in the wrong scale. I think 1000 does the work for me though.
KyrreS
Djordje
Ace
Yep, 1000 does the job.
Djordje
HP Omen
