aryastark
problem: morph lines not showing | waffle slab | rib + coffered + caisson | smart way to waffle slab
valar morghulis,
i convert this object to the morph.
but i want it to appear that hidden lines as when it was an object.
there should be hidden lines in the morph.
how can we achieve this?
Ver: AC23
Operating System: Windows 10 64-bit
Processor: Intel(R) Core(TM) i7-6700HQ CPU @ 2.60GHz (8 CPUs), ~2.6GHz
Memory: 16384MB RAM
Card name: Intel(R) HD Graphics 530
Chip type: GeForce GTX 960M
10 Replies 10
aryastark
DGSketcher wrote:
I am guessing this isn't a one time project? If you are going to be repeating this process the curtain wall tool may be your new best friend. You may need to invest some time in it but it could be worth it once set up how you want it.
I have attached a module file which you can place as a Hotlink module and then embed to see what's going on. Hope it helps.
yeess that's exactly what i was looking for.
perfect, thank you much.
and for other people who seeking for further educational click there-> https://youtu.be/uFfSfB05NMs
ps: i didn't try but this is another method may work if anyone is interested->
https://www.youtube.com/watch?v=ug_M_vqgBVk
https://helpcenter.graphisoft.com/user-guide/76685/
Ver: AC23
Memory: 16384MB RAM
