problem scaling an object
Hi again everyone, I'm having a problem scaling an object and I'm hoping for a little help. Here's the link to the screen grab:
http://screencast.com/t/QEsQzUaszm
Thanks,
Chris
4 REPLIES 4
Dwight
Exactly which element are you using?
Insulfib 11 should stretch.
Dwight Atkinson
I'm using the "DET_BATT_Insulation 11" object. It's the only insulation in that folder which is: 01General/Detailer Library/Insulation 11/
Thanks
Dwight
Insulfib 11 is your man - practice using the built-in library part search to locate it in Insulation Symbols under 07 Thermal.....
Dwight Atkinson
AH! found it.
Mucho thanks!
