Erika Epstein
problem turning >1 skin on arched opening
I have a stone veneer clad 24" thick wall. Studs are 2x4s. I want to put arched openings in the wall. The only way I have been able to get more than one skin [appear] to turn in plan is somewhat convoluted and still needs cleanup in the plan view.
This problem starts with the Door Selection Settings box on the parameters tab, CAVITY CLOSURE: the line "No of skins to turn" behaves as though it should read "which skin do you want to turn?"
The closest I have come so far to approximate this is to
1. First place a DOOR, not an opening, in the wall
2. Set CAVITY CLOSURE to TURN IN so the veneer turns in to set back door
3. With the syringe option/click alt/click the door to get its settings and apply them, ctrl/alt/click or cmd/option/clk, to an arched opening in the PREVIEW WINDOW OF THE DOOR SETTINGS BOX.
The problem with this is I still have those nasty lines between the turned skin and the fills of the opposite side of the wall i.e. the fills don't clean up as discussed elsewhere. I can add covering lines or create a patch.
Could anyone share how to correct the GDL so we can correctly control the number of skins as well as which skin(s) to turn?
Erika
Architect, Consultant
Mac OSX 10.11.1
AC5-18
Onuma System
0 Replies 0
