problem when i insert the Gsm external source library
- Mark as New
- Bookmark
- Subscribe
- Mute
- Subscribe to RSS Feed
- Permalink
ā2011-10-05
04:15 PM
ā2023-05-23
04:40 PM
Rubia Torres
so when i import it i see the loading take time and the preview of it in library decrease the performance.
can anyone recommend something, i am finally able to treat the 2d symbol of it by deleting the 2d script of the object and give it 2d symbols in the original location but what about 3d of the object that is too heavy
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
ā2011-10-05 09:28 PM
If you have SketchUp Pro this works well for all the crazy detailed stuff in the warehouse.
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
ā2011-10-05 09:34 PM
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
ā2011-10-05 09:43 PM
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
ā2011-10-05 09:48 PM
ArchiCAD does a good job with the textures and you can tweak these after import anyway. In fact ArchiCAD can handle larger texture maps than other programs (Navis is limited to about 2500 pixels wide last I checked) and performance seems to be good even with huge texture maps. I often use high res aerial imagery on my site models. I recently used one 8317x5510 pixels (though I also made medium and low res versions for export to other team members).
Another cool trick with textures is you can make high, medium and low res copies and switch between them as necessary. Just load the desired folder as a linked library (don't embed them) and make sure the file names match in each folder. ArchiCAD will automatically use the loaded texture (OpenGL may require a refresh though after switching).
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
ā2011-10-05 09:50 PM
ahmed_hassan wrote:This should work. Of course the devil is in the details. Just avoid DWG wherever possible.
also sometimes i do not have except gsm format. there is no 3ds for it shall i export it to 3ds from archicad and simplify it there?
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
ā2011-10-05 09:53 PM
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
ā2011-10-05 09:59 PM
