problem with priority in AC17
Hello I will describe my problem as much as I can.. I have section showed in picture but I cant and I cant make archicad17 to draw this correctley.. I have hidro-insulation at the toppest priority and as you can see above hidroinsulaton should be brick but because of this insulation archicad deletes all sections above in composite..
please advice
1 REPLY 1
Put the Waterproofing as the TOP skin of the basement composite slab.
