profile walls
Has anyone found a way to use wall profile with the wall, foundation and footing and have the wall show on the floor plan and the foundation and footing show on the foundation page correctly?
1 REPLY 1
NCornia
Gary,
To show a solid line for the foundation wall contour and a dashed line for the footing contour:
-The wall must intersect the cutplane in the view.
-Wall's Floor Plan Display must be set to Projected or Projected with Overhead.
-The Cut Lines should be set to a solid line type.
-The Uncut Lines should be set to a dashed line type.
Nicholas Cornia
Technical Support Team - GRAPHISOFT North America
ARCHICAD on Twitter
Tutorials
GRAPHISOFT Help Center
