"conditional formating"
Hello all.
Is there any easy way that we can have "conditional formated" saved view? In other words: can I have a saved view that all the walls are gray and only those that have a fire rating value of 60 will be marked as red. In another saved view all the walls that have a sound insulation of 44db will be marked as red...etc This can't be made with pens sets + ID numbers because some walls might have a fire rate value and not a sound insulation and another wall can have both and.....!
Similarly to renovation filter that I can a have a specific color to all new elements
Thank you
Fotis
1 Reply 1
Set all the pens to gray, make a few new (that are not used) and save it as a custom combination. Set the walls to use the new pens and there you go. After, when you want to use the same model for other phases simply set the newly created pens with the corresponding colors of the desired phase. All this can be done by cloning the Stories and changing their settings in the View Map.
