reassign F1 key as a shortcut
I want to reassign the F1 key as a custom shortcut. I have done this with every version of ArchiCad since I began using in 1990 and have become dependant on this modification. Hopefully, there is someone who has made this change.
5 Replies 5
ArchiCAD removed F1 as a shortcut key to allign with all other Windows Applications and made it exclusively for "Help". You cannot reassign this within ArchiCAD (as far as I know).
I have always used F1 for split and I'm really used to it so I downloaded a free app called "KeyTweak" by Travis Krumsick. (sorry I've lost the url). This app lets you reassign keys on your keyboard. I simply reassigned F1 to F9 and programmed Split to F9 in ArchiCAD. Now when I press F1 the computer instead thinks I pressed F9 and executes the split command. Note: This is not application specific so F1 will no longer work in any program. F9 remains F9 unless you remap this also.
PS: This would make a cool prank, you could remap a few keys on a friends keyboard, it'll drive them mad.
vistasp
Mentor
That's a good find Brewer.
Travis Krumsick's web page <http://webpages.charter.net/krumsick/> returns a blank (at the moment anyway) but his software can be downloaded from PC World <http://tinyurl.com/36ah24>.
= v i s t a s p =
bT Square Peg
https://www.btsquarepeg.com
I miss the F1 shortcut too. Thank you for the information for the application , Brewer! And thank you for the link, vistasp! I am going to try it right away!
A hugh mahalo, Brewer!
I downloaded the "KeyTweak", remapped the F1 key as you suggested, and now have the use of F1 in ArchiCad again.
This is such an important function for me.....alohas, Rich
Kia ora, no problem at all.
