reducing number of nodes in a spline
we're creating a site mesh from splines (created by magic wanding a referenced autocad file).
there are WAAAAY too many nodes in these lines, and i was wondering if there was a command or process to simplify these lines with out having to remove each node by "hand"....
any suggestions?
thanks!
13 REPLIES 13
Dwight
You toy with me now.
I did skip the step where you use the magic wand with the mesh tool to take each polyline contour to form linked nodes that can be uniformly edited..... so we can dispense with the polyline contours.
Sheesh.
Dwight Atkinson
Link
That was too funny!
Link.
rocorona
This was an old issue, that worths to me an "ArchiCAd 7" tee-shirt...
Now it is in the Archicadwiki:
http://www.archicadwiki.com/TechNotes/Handle%20huge%20surveyors%27%20drawings
_________________
--Roberto Corona--
www.archiradar.com
AC18 - ITA full on Win10
_________________
_________________
YES, segment length...it was sitting right there in front of me, duh....fantastic! thanks for the help!!
