Is there a way to reduce the number of the lines in the elevation?
The elevations have too much detail and are cramped with additional lines that I'd like to delete and I was wondering if there is аn option for a simple elevation view?
Dontknow
Right click your elevation in the navigator and choose 'Elevation settings...'.
Under 'Model Display' you can change some settings.
You could set the 'Fill Uncut Surfaces with...' or disable the 'Vectorial 3D hatching'.
Architectural construction designer, draftsman, modeller
ArchiCAD 25.
