relocated command in 19
OK, people smarter than I - where did that very handy little button go - the one in the wall dialog box that said "undo all crops". Kinda important - was there a need to hide it? Thanks, Leif
ok - I found it.... not a good change. Sometimes I undo crops & change materials at the same time - in the wall dialog box....
Link
If you're interested, this command and all 'new' ArchiCAD 19 commands ae described at our new BIM6x Blog at https://www.bim6x.com/blog/new-archicad-19-work-environment-commands.
Link.
