peter spellman
repetitive components
Hello,
I am working on a housing scheme with multiple versions of the same design (3 single family houses on one site). Can I have one design that I can repeat and have the others update to inevitable changes as the project progresses?
Any help would be greatly appreciated.
I have been learning AC9 on my own for the past 6 months and can not seem to find the solution to this.
Peter
3 Replies 3
you can put them on the same layer name....for example...wall...but give each of them seperate extension...for example wall-fpa, for scheme a...wall-fpb for scheme..etc...then you use view sets to publish them....worth a try
TomWaltz
Have you tried using Hotlinks/Modules? It sounds like they do exactly what you want.
Tom Waltz
Aussie John
yes modules!!! You can even have the module nested all into the one file
Cheers John
[/size]
