rescale
i have exported a dwg drawing into archicad how do i resale it to the correct size. on other programs you can scale by entering one distance.can you do the same with archicad.
thanks
Yes. Use the Resize command (CMD-K / CTRL-K by default, or under the Edit> Reshape> Resize menu), the select the "Define graphically" option
thanks very much
