vfrontiers
Define TEXTURE
So I'm trying to create a PLANT with a bunch of STEMS / LEAVES...
My first attempt, I modeled the shape of the leaves and distributed 100 or so and I can tell it will begin choking the system..
So, I created a .png with the stem / leaves and pushed the proper transparency.. All good..
But if I use it as just a MATERIAL applied to a PLANE, I'd have to rescale the MAP for each different LEAF...
So I got into DEFINING the material INSIDE The plant object... It all seems to work fine inside the object editor....but once I spread 100 of these to create the plant, the scaling no longer works... It is stuck on the original dimensions of the leaf object...
I think I'm looking for a way to RESET the TEXTURE dimensions each time the leaf gets placed....
Any Ideas?
Duane
Visual Frontiers
AC3.14 - AC29
:|: Enscape4.16:|:TwinMotion
vfrontiers
Here's a graphic...
Duane
Visual Frontiers
AC3.14 - AC29
Lingwisyer
Guru
Could you just include a Random command in your master script that you then use on a Mul command in your 3d script before each leaf insertion?
	! +1    : fragments index start from 1
	! -1e-6 : to avoid exactly 13
rng_open_DIM = INT(RND(13)-1e-6) + 1
Ling
