resize like in autocad?
Hello:
In Autocad i very often use the ALIGN command to resize elements.
(you can scale the distance between 2 clicked points so it makes it very easy and precise),
is there a way like that in Archicad?, because i found myself trying to use the RESIZE command of archicad but its very tedious (using percentage).
Thanks!.
1 REPLY 1
Eduardo Rolon
You need to check "Define Graphically"
Eduardo Rolón AIA NCARB
AC29 US/INT -> AC08
another Moderator
