resize like in autocad?
Hello:
In Autocad i very often use the ALIGN command to resize elements.
(you can scale the distance between 2 clicked points so it makes it very easy and precise),
is there a way like that in Archicad?, because i found myself trying to use the RESIZE command of archicad but its very tedious (using percentage).
Thanks!.
Eduardo Rolon
You need to check "Define Graphically"
Eduardo Rolón AIA NCARB
AC29 US/INT -> AC08
another Moderator
