2024-11-13 12:36 PM
Hi. I am desperate with one of my drawings. please can someone help me how to open the file to plan view instead of 3d document?
I had a 3D document saved view, due to NON OPTIMISED hatch (I think its grass or gravel hatch) the drawing crashed. Now i cannot open the drawing, because after opening the file it tries to open the last view - 3D document. then it always after 10 minutes crashes - not enough memory (32GB is not enough)
- Is there a possibility to open the drawing to plan view?
- Is there a possibility to finally optimize native hatches not to cause crashes?
- Is there a possibility to optimize bug reporter to work? (takes 20 minutes to send)
thanks.
2025-03-18 10:20 PM
I agree. 32GB is not enough. I have max for my windows os with is 64GB and I could probably benefit from twice that. As for how to open the drawing without having to load the 3D document -- "Click Abort" . If you move your cursor to the center of the screen where you are probably seeing this
move your cursor to the center of that and you will see this pop-up
You may have to click that more than once, but it sometimes stops regenerating the image quicker.
You probably already tried that.
2025-11-19 12:34 PM
HI, hatches in 3D documents still are not optimised.
Lets create hatch (fill) blacklist - which NOT to use until Graphisoft repair this
- GRASS
