Vaclav Slovak
restore the drawing to plan view / optimise hatches
Hi. I am desperate with one of my drawings. please can someone help me how to open the file to plan view instead of 3d document?
I had a 3D document saved view, due to NON OPTIMISED hatch (I think its grass or gravel hatch) the drawing crashed. Now i cannot open the drawing, because after opening the file it tries to open the last view - 3D document. then it always after 10 minutes crashes - not enough memory (32GB is not enough)
- Is there a possibility to open the drawing to plan view?
- Is there a possibility to finally optimize native hatches not to cause crashes?
- Is there a possibility to optimize bug reporter to work? (takes 20 minutes to send)
thanks.
2 Replies 2
Steve Jepson
I agree.  32GB is not enough.  I have max for my windows os with is 64GB and I could probably benefit from twice that.   As for how to open the drawing without having to load the 3D document --  "Click Abort" .  If you move your cursor to the center of the screen where you are probably seeing this
SteveJepson_0-1742331937875.png  move your cursor to the center of that and you will see this pop-up
You may have to click that more than once, but it sometimes stops regenerating the image quicker.
You probably already tried that.
Vaclav Slovak
HI, hatches in 3D documents still are not optimised.
Lets create hatch (fill) blacklist - which NOT to use until Graphisoft repair this
- GRASS
