rising / skew / sloping wall possible?
How do I draw a wall 19.8m long, 1.050m high on the one end and 2.711m high at the other with a nice slope up. (level at the bottom but 'skew' on top?
Ta,
Henry
Thomas Holm
Draw the wall full height. Then cut the upper part with using SEO (solid element operations) with an object with the desired curvature as operator, then you hide its layer.
Do a search in this forum, the question is common. Also, this tip might help (the part about roads in terrain applies):
http://www.aecbytes.com/tipsandtricks/2006/issue10-archicad.html
Just add hiding of the mesh's layer in the end.
thanks for that, after posting I realised I can create a little roof over my wall then trim to roof, then delete / hide the roof.
H
