roof accessory
I have a pizza slice shaped roof and want to use the roof accessory for wood planks. I can't seem to get the planks to run in the direction I need them to go in, parallel with the crust so to speak. What parameter do I need to change?
Jacek
When you draw the roof, the Rafters (planks?) are always perpendicular to the plate line (original reference line), change the location of the plate line and the incline direction and you will get them to show correctly.
jacek lisiewicz
arkhos-tekton, architects
carmichael, ca
Mac OS X 10.15.5
IMac Retina 5K, Intel Core I7
32 GIG Memory, AMD Radeon R9
ArchiCAD 24
thank you!!
