rgarand
roof edge problems
Hello everyone,
I have a small problem with my roof edge angle. I have attached a an isometric view. As you can see the fascia does not connect to the other fascia. I have created a roof with a perpendicular roof edge angle. My soffits are not cleaning up the way I want either. I do, however, understand why the images are like they are...yet they do not come out the way I would like them. The images attached show the soffits after "trim to roof".
I have tried to extend(overlap) the 2 roofs so that the soffits clean up...but this does not produce the corrct outcome either.
Any help would be appreciated.
Robert J. Garand
ArchiCAD USA 28-Build 6003 USA FULL and ArchiCAD USA 29-Build 3000 USA FULL
Windows 11 Prof (64 bit) - Intel i9-14900K CPU 3.20 GHz - 64 GB RAM - NVIDIA RTX 5000 Ada Generation
11 Replies 11
Jefferson
Robert,
Glad to help, or pass it on is more like it. The give away on a good miter/roof joint is that untrimmed wall, roof, column......or even the smallest sliver of it. That feature is worth it's weight in gold!
jeff white
w3d design
AC 23 Solo US / current build & library
Windoze 10 Pro 64
HP ZBook 17 G4
Intel Zeon 3.0
Twin 2GB SSD
32 GB memory
http://w3d-design.com
rgarand
The final product...This roof has a perpendicular roof edge. The valley intersection as well as the ridge intersections needed to be mitered to appear and function properly. The Soffit/fascia is just a wall, trimmed to roof. We will detail it later in the large scale details.
Thanks for everyone input on this one.
Robert J. Garand
