roof maker on complex, multi plane roof
Is there a way to build a correct roof construction using roof maker for a roof with a raised gable?
My roof is made from 2 objects and then connect>>trim elements to roof.
Roofmaker by default does not "see" a hole in the roof where the second one connects to it.
1 REPLY 1
Select all roofs and then run Roof Maker for the roof construction.
Do not forget to thick the box for the RIDGES.
