2007-02-07
08:19 PM
2023-05-23
03:21 PM
Rubia Torres
2007-02-07 08:28 PM
2007-02-07 09:05 PM
2007-02-07 09:24 PM
2007-02-07 09:34 PM
2007-02-07 09:40 PM
2007-02-07 09:42 PM
2007-02-07 10:50 PM
TurboGlider wrote:You can use the 'Change Roof Slope angle' pet palette option which appears when you click on the corner of a roof in the 3D window. Top side or underside - doesn't matter. The angle pivots around the roof pivot line, so I'd recommend placing your roof pivot line on the outside corner of the wall. It's also based on the underside of your roof, so it may help to set your roof edge angle to plumb cut, even just temporarily.
Your roof has only one pitch, but it could be a bit tricky to find right direction and angle och it. You could calculate this with SIN and COS or test with help of 2d plane and section/elevation views.
2007-02-07 11:56 PM
2007-02-08 12:40 AM
