rotate in vertical
I have problem with my model. I try to make gong to hang on the wall. I use floor tool to make a circle, but I don't know how to retate it to vertical. Please help me out, I need to turn in this On Tuesday. Thank you!
14 Replies 14
You can save it
1. from a side view as a gdl object (file/gdl objects/save selection as) or you can save it
2. as a gdl object in the floor plan using the same path and completing the GDL 3d script with: roty 90 (written in the first line of the script)
and replacing the 2d script with: project2 3, 270, 2
Regards,
Ede Abos
P.S. The picture below shows You the first way
thank you for your help. The image is so helpful. I'll try tonight.
Take a look at FrameWright - it includes tools to quickly make objects with custom profiles and rotate and cut them freely in 3D.
http://www.encina.co.uk/
Ralph Wessel BArch
Central Innovation
is that the website you post at the end of sentence?
Yes - I should have linked to the product page though, which is http://www.encina.co.uk/framewright.html
Ralph Wessel BArch
Central Innovation
Thank you so much. This is so helpful
Ede Abos, I have one more question. If I want to post gong's picture, how to do it? Because when we make our own material, it's always square image. BUT Gong is circular. I don't know how to make it work. Could you teach me? Thank you!
Sorry,
I'm a little late with my answer but unfortunately I can neither help you
(I don't know if it's possible in Archicad) because I make my renderings in 3dsMax
Perhaps can some other help you
Regards,
Ede
3D studio max can render ArchiCAD's model? I also know 3D studio MAX. Can you teach me how to transfer the model to 3D studio max? Thank you!
