2012-01-13
03:36 PM
2023-05-23
02:44 PM
Rubia Torres
2012-01-13 05:14 PM
2012-01-13 06:22 PM
2012-01-14 07:46 PM
strawbale wrote:Take a look at OBJECTiVE. It provides a tool to rotate and selection of objects about a specified axis, and can rotate in section/elevation views too. The assembly tools would allow you to toggle the cables between the finished position in the roof and a flat plan view if subsequent editing was required. It also provides a split tool that would enable you to cut your cables in plan or elevation for more complex roof layouts. The videos on the product page illustrate all these functions.
Is there anyway to rotate an object in the vertical plane so that it matches the roof angle??? The cable can be seen in front of the building
