rotated arcs after reopening archicad file
A few people in the office are having problems with arcs rotating themselves in an archicad file. After saving a file then reopening it they find that several arcs have been rotated about their axis. One person has it happening quite a lot, the others not as much.
Anyone experience this problem or know of a fix?
Thanks
5 REPLIES 5
Link
Have you downloaded the latest Update? If not try doing that from your Help menu.
Link.
Link.
After updating to the latest patch (2045) we are still experiencing rotated arcs. They are fairly infrequent though not all may be discovered.
Could this be some glitch carried over from a previous version of Archicad? Frequently drawings are copied from older versions and pasted into new work (then modified).
Link
Sounds like one for tech support mate. The only time I have seen this behavior I fixed it with an upgrade. Your assumption is probably right though - try and replicate the problem and narrow it down to a single arc. Send that file in to tech support.
Sorry I can't offer more help.
Link.
kevin b
Has anyone else come across this? Is there a fix in the works? We are on latest update 2172 and still experiencing this problem.
kevin s burns, AIA
massachusetts, usa
AC25 (1413), since AC6
Windows 10
Intel Core i7 -8700 @ 3.2 GHz~ 16 GB ram
i have experienced this problem only when i was publishing the drawing. it has been an annoyance to me but when i go to the publisher i have to to to the navigator and double click the view i am in to make sure the zoom is exactly the same. this has helped but i have never had problems with the save and close rotating the arc.
